S: AC/DC Tigværk ( alu - stål )
: 08 okt 2009, 10:10
af beyer
SPARKZ 200amp tigværk ac/dc m. ejer fl
AD-CD TIG ALUMINIUMSSVEJSER ADC200D DC MMA voltage AV 220/230/240 V 50Hz. No load voltage 60 - 80 V. Base current Adjusting Range 5-160A. Rated Output Current 160 A. Rated Duty Cycle 35%. AC TIG No load Voltage 60-80 V. Base current Adjusting Range 20-200 A. Initial Current/crater-fill current (fixed) 40 A. SP% 30-70. A C Square Wave Frequency 20-100 Hz. Rated Duty 60% DC TIG Pulse Current Adjusting Range 5-200A. Rated Duty Cycle 60%. Current Up-slope Time 0-10S. Current Down-slope Time 0-10S. Base Current Adjusting Range 5A-200A. Initial current/crater-fill current (fixed) 10A. Pluse Width Ratio 0.1-0.9. Pluse Frequency 0.5-25Hz. After Flow Time 1-25s. Arc starting Mode high frequency arc striking. Efficiency 80%. Mass 25kg. Protection Class of enclosure IP21S. Outline Dimension mm 430 x 200 x 290.
tig værk ny pris 10000,-
6 kilo argon flaske 4500,-
regulator 1000,-
samlet ( er som nyt )
stadig med 1,5 års garanti
10000,-
Tlf: 30886742
tig....
: 12 okt 2009, 12:56
af beyer
kom med bud !
